Engine problems
Engine problems
I recently bought a 91 f-150 with a efi 5.8 with california emissions. I have replaced the fuel filter, plugs, wires, cap, rotor, and o2 sensor so far. I am getting a check engine light when i drive it. It will go out and come back on while driving, and will not come on in idling. and if you turn the key off it clears the light. the exhaust smells really rich and the fuel mileage is terrible. i can't get the check engine light to stay on to scan it so does anyone on here have any ideas. also when starting cold it stumbles a little bit but then will run fine. if you need anymore info let me know and i will see what i can do for you. thanks for any and all info.
ok after letting the truck sit for about two days i went out to start it and i had to pump the gas while turning over the engine to get it started. it is about 70 here today so it should have started right up. any ideas? I bought a code scanner from ebay. i am hopin that will give me something that i can pinpoint the problem too. thanks.
I replaced the fuel pressure regulator friday and that seems to have fixed it. I can't smell a really rich exhaust anymore and i drove 80 miles to work today without getting a check engine light. and my mileage has improved. looking in the old fpr i think dirt got in it and stuck it open. i didn't check the actual pressure but the pumps stopped whining and all seems well. KNOCK ON WOOD!!!!!!!!
