No fast idle and rough start up idle
95 F350 PSD Crew cab Dually - When I first start the engine I have no fast idle even on cold mornings. Constant low / normal idle around 650-700.
Also everytime I start the engine HOT or COLD it will give me about 5-7 ROMP, ROMP, ROMP's with surging idle from 650 up to 900 with each ROMP and then smooths out.
Now I am noticing a small surge in the RPM's (about 50 RPM minor surging) both HOT or COLD and at idle or holding it steady down the road at a constant speed.
Any suggestions?
Any suggestions?
Mine was doing the exact same thing, it started have the "romp" when you first started it, then it got to where it did it all the time. See the TSB about cleaning the orfice tube and screen. I removed the fuel pressure regulator, cleaned the orfice tube, and the screen and now it idles MUCH smoother. i still have no fast idle, that is another issue. When you remove the regulator from the side of the fuel filter housing, be careful not to damage the O ring, you can re-use it. Mine had black sludge on that screen. I have read on this forum where they say you can clean it with a Q tip whithout removing the regulator, but I took mine off the truck and cleaned it out with brake cleaner. Try this, if it has never been cleaned, it will definately help.
