All depends on how you drive it. If you keep your rpms under 2000(hard to do with 4:10's) I would guess around 20mpg. But for normal driving conditions 16-18mpg is usally what these trucks get.
What kind of fuel mileage can one expect from a 96 CC, LB, 125k miles on it with 5 speed manual and 410s in the back? I believe the motor to be stock.
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
