won't kick down...
Old Jan 20, 2005 | 03:45 PM
the tank's Avatar
the tank
won't kick down...
Got a new holley 600cfm electric choke on my 1972 390 and I think the high idle is not shutting off or something...... It will not idle normaly even with carb lever in totaly relaxed position, it just keeps on "high-idling" as the manual says
Reason I ask is because the manual tells me how to adjust high idle but doesn't say anything about stopping the high idle?
Old Jan 20, 2005 | 03:49 PM
WillyB's Avatar
WillyB
You have to pump the throttle to allow the cam to move out of the way. If you are doing this and it still does not work then there must be something wrong with the linkage.
