Problems Again!!!!
Old Jan 16, 2005 | 05:23 PM
Mastimas1's Avatar
Mastimas1
Exclamation Problems Again!!!!
Ok I recently posted on how to find out what motor I have in my truck and it turns out to be a 76 390 thanks for all the help. Now I have a problem with the starter solenoid. Every time I turn the key over to crank the truck the solenoid starts smoking. I replaced both the solenoid and the starter to try and fix this problem but it is still doing the same old thing. Now I am very angry and I am about to go about fixing it by way of a pair of pliers and a cutting torch hahaha just kidding, but I am very mad at my truck. Any suggestions on what I should do or what this problem is caused by?
Old Jan 16, 2005 | 05:37 PM
gtex's Avatar
gtex
I can only think that something is wired wrong.....I tsounds like something that should be hot, may be grounded. A short! If that much current is grounding out through the smaller connections (I and S on the solenoid), then it would probably cook the solenoid. Or, if you starter lead was grounded out somewhere....
you can take the starter lead and touch it to the positive on the battery to confirm that the starter is ok. If that is good, you can trouble-shoot the solenoid. Although, you probably need a new one if it was smoking.
Old Jan 16, 2005 | 05:57 PM
Mastimas1's Avatar
Mastimas1
Ok found the problem I am not much of a tech lol. I thought I had freed the wire from touching all metal but it was grounding out on the manifold. thanks
Clarabelle
1983 - 2012 Ranger & B-Series
Dec 16, 2015 02:06 PM
rrhuehn
1997 - 2003 F150
Jan 18, 2013 06:49 AM
RVF150
Jun 26, 2012 03:09 PM
Beast12
General Automotive Discussion
Jul 9, 2007 06:51 PM
wbw189
Oct 17, 2006 07:02 AM
