refresh me on K & N filters
Back in June I got a used 2001 F350 PSD, immediatly i went out and bought a k&n air filter for the stock air box. To my suprize, people on this web site strongly disapproved. I took it out right away. Now in need of an air filter, i am wanting to put in as long as i seal it real good with grease. What do you guys think?
I ran an K&N in my '99 PSD for 60,000 miles & took it out for good. Way to much "dusting" was getting thru to the engine. Even with a well maintained 20,000 mile air filter the K&N still does not filter the fine dust, IMO.
If you live in a non-dusty driving area, then you shouldn't have any problems with Dusting of the inner-engine.
Never had a problem with the K&N back in my stock filter days. My uncle and two of my friends stil run the K&N panel.....I have had to use a bead of RTV around both sides of the seal to keep dust frm getting around the filter, but none of us have had a problem yet with the actual filter media.
Check out www.bobistheoilguy.com/airfilter/airtest1.htm - it might help you decide if you want to run a K&N on the street. I use a K&N on my boat but would not use one for a daily driver; JMHO. Whether you run paper or oiled cotton/foam, it's a good idea to put silicone grease on the gasket area.
Steve
Steve
