Superduty auto-locking 4X4 hubs
#152
WOW....Your not going to believe what the problem was. Altho my right front Hub lock still needs to be fixed, I found all the noise was NOT from the front but from the back right wheel. Please keep in mind this truck was just safetied, the backing plate that holds the emergency brake was rotted out. I had tested the brake the day before this all started and BAM....it let go and kind of made a mess back there.
The dealer says he's going to come good for this and have a talk to the garage that did the safety, BUT we'll see how nice he is when he finds out that the plate sold here at the Ford dealer is ONLY in a kit and it's $500 for the kit. Does anyone know what this plate is worth and have a part# for it...just the plate....2004 F250 single wheel 5.4 l motor. Thanks.
I'm going to pull the hub lock this weekend and see what i can do with it. With all the info here, i'm pretty confident i'll have success with a fix. I'll post when i find out what's wrong with it and how I fixed the problem.
Thanks,
Chris
Thanks,
Chris
#153
#154
#155
#156
Thank you Dick.
I understand that the weight will be something to look at, But at $150.00 each it will be still worth looking at from this end to have them shipped out. I can find out the weight of mine to get the prices.
I will try ebay as well. Once again thank you for your advice.
Kindest Regards
Phil Bell
Kindest Regards
Phil Bell
#157
problems again
ok i read the first 5 pages of this thread and wish i would have before i started this adventure....
i have an 01 f250 v10 with auto locks....they are ALWAYS in the lock position and have been for the past 150K with no problems! let me expalin I am a logger & snowplower and this truck is in 4wheel drive almost every day the autos are a great thing just flip the switch and hear the clunk and away we go!
so the front pumpkin seal went out and the grage put a new one in and said the driver auto was junk and need to be replaced. 300 from dealer their cost 225!!! the only junk yard that had one in a 3 hour drive wanted 125... so i installed it and upon locking them back in the passanger black piece and the o ring poped out!!!! seems the piece is worn out.... after messin with it for a while i got it back in to where it would turn the hub... i locked the hub and went to the woods only to spin in 2 wheel!! front axel turns and i hear the 4 wheel engage when the switch is turned... either the bad hub is leaking the vacum or something else?
thoughts?
chad
firewoodguy1@comcast.net
thoughts?
chad
#158
#160
I think they "fit" but the **** is so recessed in the wheel hub that you can't get to it.
Let's wait and see if anyone has any solid experience with DRW hubs though.
One way to see if they would fit is to check the part numbers for the stock locking hubs for both DRW and SRW.
Also, an email to Warn is returned within a day or two. Contact them through their website and see what they say (and report back here with it).
Warn Industries - Winches, Mounting Systems, Accessories, Hubs, Air Compressors, Flares, Lights, Body Amor
#161
2005 f250 harley edition 6.0 diesel
I read all of this and mine did the same type deal vent went to defrost mode. I replaced the vacuum pump and the switch 4wd worked good during the winter. Now spring time I hear a clank clank clank noise going down the road (like your on a rollar coaster) comming from the driver side. A buddy went offroading got stuck (stock truck) and i went in in only 2wd I had no 4wd i swittch hubs to auto switch 4wd light comes on dash but 4wd not working. I jump out click to lock no good. Im thinking my hubs are junk. Now i was told warn dosnt make a kit for my truck. Id drop this auto crap in a heart beat cap the vaccum line and make sure when i lock i got 4wd.
Does warn make a kit for the 2005 F250 super duty?
#162
#163
I have been using my autoloc hubs quite extensively with all of the snow in my neck of the woods. I haven't had any failure in attaining 4x4 in the 5300 miles I have on the truck so far. Is there something I should be aware of as far as counting on my 4x4 when needed? I thought that the combination auto/manual hubs were a good idea but sure don't want any surprises when I need good traction.
I would have preferred a system like my last several trucks - manual transfer case w/ auto hubs - but that's NA from Ford. And I didn't want an electronically-controlled transfer case.
Apparently the earlier Ford systems had problems but the new ones are better.
#164
#165
