engine swap
Old Jan 7, 2005 | 11:29 PM
4x4ford95's Avatar
4x4ford95
Question engine swap
anybodyever change from 302 to H.O. 302 i need a little more get up and go for towing in 1995 f150 4x4 or maybe i need to go to bigger endine
Old Jan 8, 2005 | 02:28 AM
Ponyracer's Avatar
Ponyracer
I would suggest going to a 351w. They came as an option and will swap right in for the 302. Also, a gear swap might be in order.
Old Jan 8, 2005 | 04:19 AM
dpbrowne's Avatar
dpbrowne
I am thinking about doing the same thing with my 96 F150. The engine is approaching 300K, still running strong but I am starting to make the plans. Is the firing order the same? Also, does the computer have to be changed? Wht else?
Old Jan 8, 2005 | 06:50 AM
EPNCSU2006's Avatar
EPNCSU2006
On the '96, the firing order should be the same as the HO firing order. The computer would not have to be changed. Just drop in the long block and you should be ready to bolt on all the truck accessories and wiring.
