Who's got Big Blocks in their Effies?
Old 01-07-2005, 03:51 PM
LA_50_F1's Avatar
LA_50_F1
LA_50_F1 is offline
LA_50_F1 is starting off with a positive reputation.
Anyone have Lincoln 460's in their trucks -- besides jniolon...
What other Big Blocks do you guys have? Trannys? Rear-ends? What are Posi-rear ends like? I have never had the pleasure to drive a '70s-era bruiser but would like to know what it is like...
Cheers,
S.G.
Old 01-07-2005, 08:27 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
I'm doing the 460/C6, with the ford/Lincoln 8.8 rear, 3.55 with Posi, disc brakes all the way around.
Objective is to be able to burn rubber at any speed!
Sam
Old 01-07-2005, 08:53 PM
atccracing
atccracing is offline
atccracing is starting off with a positive reputation.
Now thats what I'm thinkin! I'm building my 51 now, fitted in the 460/C6, just finished welding all the brackets on my 9", and gotta love those big fat Mickey T's.....
Old 01-07-2005, 09:01 PM
tmyers's Avatar
tmyers
tmyers is offline
tmyers has a good reputation on FTE.tmyers has a good reputation on FTE.tmyers has a good reputation on FTE.
I have a 502 going into mine mated to a C6, GV overdrive and a 9 inch. Short block is down minus a few mods. Will be looking at 600+hp and 700+ torque.
Old 01-07-2005, 10:32 PM
2001psd's Avatar
2001psd
2001psd is offline
2001psd is starting off with a positive reputation.
My 55 Im workin on has a lincoln 460, t-10 4 speed, 9 inch rear with 3.73 gears.
Old 01-09-2005, 04:53 PM
TryMe's Avatar
TryMe
TryMe is offline
TryMe is starting off with a positive reputation.
Why do you wanta go with a big block ????? Im not knockin a big block in a early ford. Matter fact I have a 50 Ford f-4 holmes wrecker with a mild reworked 460 and 4 speed,also a 52 mercury M-3 1-ton dually p.u. thats has a blanced and built 460 EFI. Its also running a garrett turbo 5-speed 411 gears. And ya it halls ***. and able to out run most 5.0 stangs on the street. But I built it 5 years ago,not knowing gas would go so high. If I built one today. It would be a 302 or 351 windsor.my 52 merc has won in a lot of shows. But my trucks are not garage trucks like most. They are driven a lot. Almost daily. You might want to think about how many gas stations you will be able to pass. And being able to have fun with it without it hurting your pocket book. You can count on 9-10 miles per gallon if your lucky drivin normal.. And at almost $2 dollars a gallon. Be ready to be pulling out them jacksons quick. Most guys I have run across with a lil F-1 were more then pleased with there small block mill. Later !!!
Old 01-09-2005, 05:50 PM
tmyers's Avatar
tmyers
tmyers is offline
Because I'm not building it to be a daily driver. I may even run race fuel only through it. This is a toy, plan and simple. I will have well in excess of 50k in it before its done. The cost of gas is the last thing I'm concerned with.
Old 01-09-2005, 05:52 PM
Purple55's Avatar
Purple55
Purple55 is offline
Purple55 is gaining momentum as a positive member of FTE.Purple55 is gaining momentum as a positive member of FTE.
I've got the 460/C-6 combo and an 8.8 in the rear with 273's and disc brakes.
Old 01-09-2005, 06:24 PM
hot1958
hot1958 is offline
hot1958 is starting off with a positive reputation.
my 58' has a 70' 383 roadrunner engine,727 trans 9'' with 3.70 gear's.like tmyers said i am not worried about the gas price,i just want to have some fun.i am planning to do a little racing from time to time,and i have 5 gal.race gas in it now.will be starting it in the spring.there is an old saying no replacment for displacment,big block's rule.all you big block guy's have fun.
Old 01-09-2005, 06:44 PM
56 Effie Aurea's Avatar
56 Effie Aurea
56 Effie Aurea is offline
56 Effie Aurea is starting off with a positive reputation.
Originally Posted by LA_50_F1
...What other Big Blocks do you guys have? Trannys? Rear-ends? What are Posi-rear ends like? I have never had the pleasure to drive a '70s-era bruiser but would like to know what it is like...
S.G.
Since the question is "what OTHER big blocks..." I guess I can answer .
I'm running a 450+hp modified 402 bbc L-47 truck motor...until I find my 429 CobraJet . In the meantime, the trans is a TH400 with a B&M kit and GearVendors OD unit (love that thing!!) The rear is a Mopar 8 3/4 3.91 ratio posi. The truck came with all this and since it runs so good, I'm not about to change it for now. I can be cruising at 40mph, hit the switches to turn off the OD unit and turn on the electric TH400 kickdown at the same time and lay 30 ft of rubber ! Gearheads want to know what the hell is in there to do that!
Since this is not a daily driver gas is not an issue....it can't be at only 4-5 mpg ! My daily driver is a 2001 V6 F-150......but not nearly as much fun to drive.
Norb
Old 01-09-2005, 07:13 PM
tmyers's Avatar
tmyers
tmyers is offline
Well I may get rid of my 502. Someone made a suggestion of running Boss 429 heads. This is intreging to say the least. A 572 with hemi heads may just be the ticket.
Old 01-10-2005, 11:14 AM
fish-albuq's Avatar
fish-albuq
fish-albuq is offline
fish-albuq is starting off with a positive reputation.
ive got a 460w/c6 tranny and ford 9" in the rear. not sure of what gears are in the rear but plan on putting posi as soon as i can. got all my donor parts from a '74 lincoln. good luck!!!!
Old 01-10-2005, 11:49 AM
superman64011's Avatar
superman64011
superman64011 is offline
superman64011 is starting off with a positive reputation.
71 Lincoln 460/C6 combo.....4 bar link system on a 9 inch rear end......4.11 MAE Racing(Andale) Posi unit....
Old 01-10-2005, 12:23 PM
sparky30_06's Avatar
sparky30_06
sparky30_06 is offline
sparky30_06 is starting off with a positive reputation.
ok big block define big block?? does a 6.9 liter international diesel count, oh yea with a turbo on it also. c6 trans, going to the trans shop hopefully next fall or sooner for a trans brake and to reverse pattern. 9" rear end with strange street/strip 35 spline axles and a strange third member with 3.25 gears and a detroit locker.
Old 01-10-2005, 06:40 PM
hot1958
hot1958 is offline
hey sparky,i would definately say that is a bigblock.i have seen a set up like your's before,and the truck was pretty quick to.the same guy has a 69'f-100 with a 7.3 diesel that run'shigh 9's in the 1/4 mile.both truck's are cool.i like your truck,i think the 58's are the best looking of the 57-60's f-100's.have fun with it/scott.
Quick Reply: Who's got Big Blocks in their Effies?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
