Who's got Big Blocks in their Effies?
Old 01-11-2005, 06:47 AM
sparky30_06's Avatar
sparky30_06
sparky30_06 is offline
sparky30_06 is starting off with a positive reputation.
hey scott the truck you are talking about is owned by a very good friend of mine and i use to pit crew for him and worked on that truck while he was building it. you probably saw it run at byron in the mid 90's?? he still has the truck and just takes it to car shows now and drives it around town. that truck was alot of fun and man did she get up and move too. i rode in it once, even though there is no passanger seat just sit on the roll cage, and man that was fun.
Old 01-11-2005, 12:11 PM
six7seta's Avatar
six7seta
six7seta is offline
six7seta is starting off with a positive reputation.
got a 460, 351, and 400 for mine... it was fun trying to figure out how to make it an easy "weekend swap"
Old 01-11-2005, 01:41 PM
55 panel
55 panel is offline
55 panel is starting off with a positive reputation.
big blocks
hi dude got a 454 big block chevy in me 55 panel van,,,,,cruzin round the streets dont even have 2 put me foot down,,,cant bit the power and torque of a big block............hopin 2 race it at santa pod england this summer,...runnin big fat mickeys on back......DONT LISTEN 2 ANYONE ELSE BIG BLOCK IS THE ONLY WAY 2 GO...WEATHER IT BE A FORD OR CHEVY...CHEERS gary
Old 01-11-2005, 03:37 PM
poolpro51's Avatar
poolpro51
poolpro51 is offline
poolpro51 is starting off with a positive reputation.
Originally Posted by 56 Effie Aurea
Since the question is "what OTHER big blocks..." I guess I can answer .
I'm running a 450+hp modified 402 bbc L-47 truck motor...until I find my 429 CobraJet . In the meantime, the trans is a TH400 with a B&M kit and GearVendors OD unit (love that thing!!) The rear is a Mopar 8 3/4 3.91 ratio posi. The truck came with all this and since it runs so good, I'm not about to change it for now. I can be cruising at 40mph, hit the switches to turn off the OD unit and turn on the electric TH400 kickdown at the same time and lay 30 ft of rubber ! Gearheads want to know what the hell is in there to do that!
Since this is not a daily driver gas is not an issue....it can't be at only 4-5 mpg ! My daily driver is a 2001 V6 F-150......but not nearly as much fun to drive.
Norb
If your looking for a 429 complete with a c-6 tranny I have one.
Old 01-11-2005, 03:41 PM
poolpro51's Avatar
poolpro51
Originally Posted by hot1958
my 58' has a 70' 383 roadrunner engine,727 trans 9'' with 3.70 gear's.like tmyers said i am not worried about the gas price,i just want to have some fun.i am planning to do a little racing from time to time,and i have 5 gal.race gas in it now.will be starting it in the spring.there is an old saying no replacment for displacment,big block's rule.all you big block guy's have fun.
In my 56 I'm running 1969 Roadrunner engine & trans. 8 3/4 Imperial rear end with 323 gears. Plenty of power, more than I use. LOL
Old 01-11-2005, 05:00 PM
Jet Jock
Jet Jock is offline
Jet Jock is starting off with a positive reputation.
Purple 55
Are you still building that truck? Am I going to see it this year in Knoxville? Hey if you and Ms Purple are going I have an extra room in the group I have reserved.
Jet Jock
"I drive a 'girly' 302 because, when I want to go fast, I go to work"
Old 01-11-2005, 06:19 PM
sierraben's Avatar
sierraben
sierraben is offline
sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.
I'm working on a 55 F100 with:
65-352 FE big block
Borg Warner T-18 Trans w/
Advance Adapters Ranger Torq Splitter
(27% overdrive)
Also have a C-6 and T-10 in storage
just in case........
Old 01-11-2005, 10:25 PM
Purple55's Avatar
Purple55
Purple55 is offline
Purple55 is gaining momentum as a positive member of FTE.Purple55 is gaining momentum as a positive member of FTE.
Originally Posted by Jet Jock
Purple 55
Hi ,Bill!
Sounds good! PM me with the details.
The '55 might make it there.Haven't been able to work on it the last couple of months,so I'd better get busy when I get back from my South Dakota ice fishing trip the end of this month.
Old 02-02-2005, 06:23 PM
49panel
49panel is offline
49panel is starting off with a positive reputation.
Talking bb ford
i was wondering if anyone had some pics, do's and don'ts for 460w/c6 in a 49 panel headers, mounts battery local. ect.... just building a toy/tire burner and wanted do it right the first time
thanks AJ
Old 02-02-2005, 06:46 PM
DyceDesign
DyceDesign is offline
DyceDesign is starting off with a positive reputation.
I have a 427 FE for my 51 F-1 will be starting to look for a C6 for it shortly....I have a 9" in the truck already..
Old 02-02-2005, 06:50 PM
49panel
49panel is offline
hey ,DyceDesign what did you take your 9" out of
Old 02-02-2005, 11:50 PM
boilerbots's Avatar
boilerbots
boilerbots is offline
boilerbots is starting off with a positive reputation.
Originally Posted by sparky30_06
ok big block define big block?? does a 6.9 liter international diesel count, oh yea with a turbo on it also. c6 trans, going to the trans shop hopefully next fall or sooner for a trans brake and to reverse pattern. 9" rear end with strange street/strip 35 spline axles and a strange third member with 3.25 gears and a detroit locker.
You have any pictures to share? I would like to see how your engine and tranny setup looks. Are you running a non-computer controlled motor?
  #28
Old 02-03-2005, 07:14 AM
sparky30_06
i will get some pics of the motor and trans set ups hopefully this weekend. the 6.9 is totally mechanically controled motor, no computers stuff on this old girl. would be interesting to get one of the 7.3 powerstrokes or one of the NEW 6.0 powerstrokes. or that little experimental powerstroke that is heading for the F150s. hhhhmmmm might need to build another truck soon.
  #29
Old 02-03-2005, 08:03 AM
galaxy5oo
galaxy5oo is offline
galaxy5oo is starting off with a positive reputation.
I have a 390 in my 51 F1 out of a Galaxy. I am about to pull it out this weekend and redo the motor mounts, because I am clipping it. My rear end right now is out of a Gremlin. It was on the truck when I bought it a couple of months ago. They are tough little rear ends, but I am going to replace it with a 9" asap and flip the rear end and notch the frame.
  #30
Old 02-03-2005, 11:24 AM
AmeriKen
AmeriKen is offline
AmeriKen is starting off with a positive reputation.
Mine has a 460/C6 with a Dana 70 Detroit locker. I'm running some old 12.5" wide X 16.5" tires in the rear and they offer no resistance when I power brake it. I did it the easy way, however, I put the sheetmetal on an 84 E350 chassis.
I made mine to tow a trailer hauling restored tractors and dozers to tractor shows.
Ken McWilliams
Dayton, Oh
Quick Reply: Who's got Big Blocks in their Effies?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
