Shelves...screws or nails?
This is not directly related to my shop, but if it works out I may end up building some for myself. My Dad somehow has managed to wind up renting several storage buildings in the past few years. Right now he has 3 and I have been telling him to consolidate and get rid of two of them. I think I about have him talked into it. You know how these things go You have a few things, you decide you need storage space and before long you have moved a couple of times and you have numerous storage buildings full of stuff. Well these are not full, he just is not taking advantage of the space he has.
Anyway, I am going to build him some freestanding storage shelves for his stuff, mainly for boxes and storage containers. My question. Is it ok to use a good wood screw to put it together? Each will be roughly 6 ft. tall, 6 ft. long and 2 ft. deep. The shelves will be framed with either 2x3's or 2x4's and have a piece of plywood screwed to the top. The legs will likely be 2x4's in an "L" shape on each corner. There probably will not be a shelf at the very bottom, so the first will most likely be 20" from the floor. The only reason I am asking about the screws is because I think it will be easier for me to assemble by myself that way. Trying to get the two legs on each corner level while hammering away might prove to be a task. And my experience with pine 2x4's, they usually split when you try to put nails too close the ends.
I am not set on any design, but I basically want to know if the right screws will be just as good as nails.
Hey,
Actually, it's been my experience that wood screws work better. My dad got mad<!****ed> after I bought my truck and even more mad<!****ed> after he found all the spare parts that came with it. I started nailing together a shelving unit and had nothing but problems. I screwed everything together. I had to pre-drill some stuff, but it was well worth the time because nothing split. I would definately use wood screws. Even bad screws worked for me. Good luck with your dad!!... and I was hoping it would get easier with the years!!
Erik
Erik
I can't blame him entirely, some of it is my junk
Back to the screw vs. nail thing. I always thought a good wood screw would provide more grip with less problems. It was a friend that told me not to use them, that it would be more sound with nails. Maybe he thought I was going to use drywall screws.
Just make sure you use good quality screws. There are some horrible screws out there. The gold ones at home depot are absolute garbage. They will easily lose their heads when you put them in or snap in half if you put any stress on them. I have also used stainless deck screws that were really bad... low grade of stainless for sure.
I use these these heavy galvanized wood screws I get from menards everywhere and have had no problems with them. I've switchted to 6 lobe (torx T25) for everything because I think it gives the best grip. If you predrill it's not a big deal though, anything will work.
Go with the screws!!!
If you put a 'back' on the shelves, it will stiffen the structure, tremendously.
Hint:
Don't use plywood for the shelves, UNLESS you put a solid wood strip along the front edge. The plywood will support about 1/3 to 1/2 what solid wood will.
Particle board. . . never!
The back:
Use 1/2 inch plywood. Plenty strong and stable for that.
I built some free-standing shelves for my garage, several years ago. The shelves look like big boxes, turned up onto their edge.
Use pressure-treated lumber for any part that will sit on the ground/concrete.
The lumber will draw moisture and rot, if you're not selective about the wood.
Bottom line. .
Screws are much stronger than nails. (Add glue and you have an unbeatable combination.
Hint:
The back:
Bottom line. .
The only square drives I have found locally are stainless ones at the Depot and Lowes. They are quite pricey I don't mind paying that much as long as they are quality stuff, but I don't know what is and what isn't.
BTW, thanks to everyone for your opinions. It makes deciding on what to use a lot easier.
