who sells a drop axle?
Old 01-04-2005, 08:08 PM
fish-albuq's Avatar
fish-albuq
fish-albuq is offline
i appreciate all the input on the drop axle and think i got what i needed out of it. but who sells a 3 or 4" drop for a 49 f-1? i found for a 52 and up but not sure of who to look to for a 49. thanks again fellas.
Old 01-05-2005, 12:11 AM
Overkill-F1's Avatar
Overkill-F1
Overkill-F1 is offline
A '52 axle will be the same as the '49. Ford changed the spindles and front brake drums in '53 for the trucks. ...Terry
Old 01-05-2005, 10:47 AM
fish-albuq's Avatar
fish-albuq
thanks terry. i thought so but wasnt sure.
Old 01-05-2005, 02:14 PM
imlowr2's Avatar
imlowr2
imlowr2 is offline
fish- check out this website. I got my drop axle from them.
www.so-calspeedshop.com
Old 01-05-2005, 05:26 PM
Christopher2's Avatar
Christopher2
Christopher2 is offline
How much was it I did not see anything on their site?
Old 01-05-2005, 06:03 PM
imlowr2's Avatar
imlowr2
imlowr2 is offline
I paid $350 for it, but I purchased it at the Long Beach Auto Swap Meet. So Cal has a spot there. I know they carry them. I'm surprised its not on the website?
Roadsters.com also carries axles. Check out this article on dropped axle, it'll help also.
http://www.classictrucksweb.com/tech...traightxxlebb/
Old 01-05-2005, 06:09 PM
mikesfordf1's Avatar
mikesfordf1
mikesfordf1 is offline
You can get a 48-52 dopped axle from Cenpen.com. They don't show one on their website but they do have them.
Old 01-05-2005, 11:45 PM
fish-albuq's Avatar
fish-albuq
how much modification does it take? id really like to do it but dont need a lot more mods. right now. i know the tie rod ends need to be extended do they make all that in a kit?
Old 01-06-2005, 07:06 PM
mikesfordf1
You will also have to modify your drivers side shock tower. The drag link will hit the shock if you don't extend the shock mount out.
Old 01-06-2005, 07:46 PM
imlowr2's Avatar
imlowr2
imlowr2 is offline
mikesfordf1- When I got my dropped axle, it came with new U bolts for the front, and also came with shock plates. You also have to change both sides, not just the driver's side, because then you have two variations of the shocks. Changing both shocks plates allows you to use the same type of shock. I know I went with a different shorter shock in the front due to travel of the shock. Don't know the number of the shock off hand.
Old 01-08-2005, 02:04 PM
mikesfordf1
You will just have to extend your drivers side shock tower mount.
