1978 - 1996 Big Bronco
Little things that help
Old Jan 4, 2005 | 02:35 PM
th0mpson182's Avatar
th0mpson182
Long time no post, my truck has recently reached about 94,000 miles on it (96 XLT with 302). I am replacing a blown header, fuel filter, spark plugs, wires, solenoid, and fan belt. Can anyone else recommend any other things to replace while I am in the mood for a quick fix-up? Also I was told that since I couldn't even remember the last time these items were replaced that there is a good chance I will probably gain back about 20 horsepower... is that true?
Old Jan 4, 2005 | 11:24 PM
greystreak92's Avatar
greystreak92
Oh yes...you will see a marked improvement if its been some time since all the "routine" stuff was done. The F/F will really regain some "Umph". They get really gummed up quicker than you'd expect. While you are getting the fuel and spark stuff cleaned and tweaked, might consider doing the same to the air-handling components; PCV valve, breather filter (in the bottom of the airbox),and air filter. If you are really looking for a thorough swab on the intake end of things, clean the throttle body assembly and IAC valve with throttle body cleaner. (Make sure the cleaner is suitable for throttle bodies an NOT just regular carb and choke cleaner). You WILL feel a difference.
Old Jan 5, 2005 | 04:16 PM
JBronco's Avatar
JBronco
Distributor cap and rotor.
bigbadben
1997 - 2003 F150
Jun 15, 2020 03:42 PM
palmrose2
26
Oct 25, 2017 11:37 AM
riverrat41
6.7L Power Stroke Diesel
Jun 1, 2015 03:07 PM
iowa 7.3
34
Feb 10, 2013 01:52 PM
tildenalso
Oct 31, 2007 12:32 AM
