Front Mounted Reciever Hitch
Check with the winch mfrs - they sell quick-mount winches that go in a Class III receiver, and most sell the front receivers for many trucks. I know Ramsey sells some. All F-150s & Broncos had the same front frame horns until around '90 when they put in the accordion frame in preparation for air bags.
on
Warn lists part # 26370 as one that'll fit 80-86 Ford trucks with coil front springs, that should do the trick for you... Although, I'd just build one myself... My truck already has most of what's needed in place from the spare tire carrier I deleted...
Evan
86 F250 HD XLT Lariat Explorer 4x4 ex. Extended Cab: 460 with factory 2.25" catless duals to the muffler(still running the stocker aaargh)
/T19(syncroed granny low)/BW 1345/3.55 geared Full Floater 10.25 and Dana 50 TTB/ 265/75R16 Hankook FR04's on 16x8 Whitespokes(street tires... Need mudders)
78 F150, 351M/C6, eventually to be repowered with a 400
Evan
on
Steve: Yah, some homebrew deal... It was strong enough to tow the truck with, mostly 1/4" angle... they added an extra x-member at the nose of the truck, and, it's 3/8" plate, it's bolted on, but, I just couldn't justify removing it because I was thinking front receiver at the time...
Evan
Evan
