double checking its the wheel bearings.
just double checking. I am fairly sure that it is the wheel bearings. I can turn the wheel, but not easily at all. the hub is removed, as is the brake caliper...when i turn the wheel, it is very dificult. It is not in 4wd, and the axel is not turning at all. Just checking before I spend the money, this means the hub assebly needs replaced as most likly the wheel bearing...and the wheel bearigns can not be replaced individually, the entire assebly must be replaced...correct?
best place to purchase?
Computermike
03-13-2016 09:52 PM
garydmundy
07-03-2013 12:22 AM
KoolAidMan888
1999 to 2016 Super Duty
19
03-12-2011 08:30 PM
ATG_Tuning
02-26-2010 09:09 AM
