To end the confusion: BioDiesel is not Vegatable Oil!
this is from http://www.biodiesel.org/
Biodiesel can be used in any concentration with petroleum based diesel fuel in existing diesel engines with little or no modification. Biodiesel is not the same thing as raw vegetable oil. It is produced by a chemical process which removes the glycerin from the oil. For those of you who do not allready understand BioDiesel please read the following:
http://www.biodiesel.org/pdf_files/Performance.PDF
I hope this will help clear the air and end the unjustified negative comments about BioDiesel. "I grow it, and I use it."
Last edited by Daryl Hunter; 01-10-2005 at 09:59 AM. Reason: Removed bold flags - weren't working
be careful guys here is a ford message
Ford's Position on Biodiesel:
Ford is advising that any of their vehicles powered by a diesel engine, regardless of manufacturer, may exhibit engine or fuel system problems when using fuels with greater than 5% Biodiesel. Any problems when using fuels containing more than 5% Biodiesel should be referred to the fuel manufacturer. Ford only recomends using fuels containing no more than 5% Biodiesel (B5) in their diesel powered vehicles. In addition, as per World Wide Fuel Charter (WWFC) catagory 1-3, fatty acid methyl esters (FAME) must meet EN14214 and ASTM D 6751 specifications. Broadcast Message 0884.
