Radiator hose
Old Dec 26, 2004 | 08:52 PM
DSP's Avatar
DSP
Radiator hose
I own a 95, 7.3L PSD. I recently replaced the lower radiator hose. The stock radiator hose has a metal spring insert. I ruined it trying to remove it. Is this spring necessary? What is it used for?
Old Dec 26, 2004 | 09:31 PM
realhp's Avatar
realhp
The spring is used to keep the water pump from collapsing the hose while it is pumping which will cause antifreeze not to circulate through the engine.
