fuel pressure regulator testing
Old Dec 23, 2004 | 10:00 AM
seth1's Avatar
seth1
is there a way to test the fuel pressure regulator? i thought i once heard that a vacuum tester could test it, but not sure.
Old Dec 23, 2004 | 11:32 AM
tomw's Avatar
tomw
Two things worth mentioning: 1) if you pull the vacuum hose from the regulator, and it leaks fuel, it is broken. 2) you can get a (~$30) pressure gauge that will connect to the schrader valve on the fuel rail to test the regulator. The one I got has a releif valve and relief hose to collect the fuel that ends up in the hose connected to the rail.
Vacuum gauges indicate vacuum. I suppose you could tee into the regulator vacuum connection if you want to see the vacuum applied to the regulator. I think the returnless systems may not have a regulator, but would only bet Your paycheck on that...
tom
Old Dec 23, 2004 | 11:37 AM
Rockledge's Avatar
Rockledge
Fuel Pressure Regulator Test
This test checks the operation of the fuel pressure regulator to make sure it changes line pressure in response to changes in engine vacuum. This is necessary to maintain the proper operating pressure behind the injectors and to compensate for changes in engine load.
With the engine running, disconnect the vacuum hose from the pressure regulator. As a rule, fuel system pressure should increase...with the line disconnected. No change would indicate a faulty pressure regulator, or a leaky or plugged vacuum line.
If the diaphragm inside the regulator is leaking, engine vacuum will suck raw fuel into the intake manifold through the vacuum hose (look for fuel inside the hose). Source
If you are having fuel pressure and/or fuel delivery problems, like tomw I recommend you do a full system pressure check. The link above is a good source for that, and Ken00 has even put together a more Ford-specific test with specs:
http://fords.kilonet.org/ken00/FuelPressureTesting.doc
