how much drop should i expect from installing the M-II front end?
i am getting ready to install the mustang II front end in my 59, and was wondering if i should go for stock spindles or dropped ones... how much of a drop should i expect to get from just putting the m-II front end on if any over the stock height?
adam
adam
I think it depends on the mfgr of your kit's crossmember. When I ordered the MII setup for my '51 F1 from TCI last month, I asked the same question, and they reported a 2"drop from stock height. But I suppose the crossmember could be built differently by different mfgrs, which may change the location of the suspension parts on your frame. I was fretting over this myself, wondering if I should order the stock or dropped MII spindels, so TCI (via Tim's Hot Rods) said to try the stock, and if I want the truck lower I could trade them in for dropped spindles at no charge. They're good to work with.
Gary
Gary
Dropped spindles?
Check out my gallery. The last picture is with the lower A-arms level which is where they recommend final ride height to be. My kit is the Fatman Stage II and the tires are 15". One thing I like with the Fatman is a low appearance but approx 5 or 6 inches between crossmember and ground.
