Oil pressure
When I start it cold, the oil presure guage doesnt move, it stays at the needle's resting point.
after a short period, typically a few minutes, it swings (abruptly) to the center of the point on the scale which is where it normally runs at.
Every so often the guage returns (abruptly) to the resting point again.
Because the guage shows only normal or zero and never anywhere in between, I tend to think that the sending unit must be faulty, but I just dont know for sure.
Anybody experience this before?
By the way, I will be attaching a test guage to see what the pressure truly is at start up, just to be sure.
Any help appreciated
If you want to rule out the sending unit, ground the wire and operate. If the needle sweeps like before, then look at the gauge or the wiring. Of course, make sure you have good oil pressure to start.
On my Aerostar it is either none or midrange. Just like the newer Miatas. It's not really a gague at all.
1) The water temperature gauge is for real. At exactly the C mark, it corresponds to a resistance of 74 ohms on the sender, which is about 150 F. Near the H mark, the resistance is 9.7 ohms, which is about 295 F, which would really be cooking your engine. The middle of the gage corresponds to about 26 ohms, or 215 F.
2) The oil pressure gauge is bogus. That is just on/off. Below 4.5-5.5 psi, it's off and the gauge reads below the L. Above that, and the switch closes, bringing the reading to slightly above the middle.
That brings us to your situation. I believe you may have a bad engine ground or the connector on the sender might be coming loose. Pull the connector of the sender and crimp it down a little to make sure it's snug on the sender. Mine was doing the same thing (plus a couple of engine misses here and there) until I wised up and started to ground the heck out of the engine. Nothing fancy, just a couple of 12-gage wires with 3/8" eye-connectors soldered onto both ends. One end goes to the bolt on the negative battery terminal, the other end goes to the a convenient bolt on the engine (the bolt securing the oil filler tube is a good candidate). I also did the same to the frame just for the heck of it. Now all that peculiar behaviors and the engine misses just went a way, and the engine is way smoother than before.
