99 dash removal
Old Dec 19, 2004 | 12:50 PM
dougsbart's Avatar
dougsbart
99 dash removal
can anyone help me get my dash off. i have removed way more screws than necessary im sure. i just need some step by step. i have read some posts in reference to f150. do i need to remove/drop steering column
Old Dec 21, 2004 | 12:13 PM
99ExpeditionXLT's Avatar
99ExpeditionXLT
You must remove the headlight switch to access mounting screws.
I'm not sure if this will be correct, but here goes. First you turn the headlight switch to on, then lightly pry off the headlight switch from the switch shaft. Then you rotate the switch 180 degrees and put it back on. Now turn the headlights off and pull out on the whole plastic module. The rotated switch unlocks catch flanges. Once out, and unhooked from the wiring harness, you can access a bolt, or two that holds the dash on. These are only some of the screws you will need to remove, there are others, but I don't think they are hidden.
Ecarlton1991
Aug 28, 2011 01:44 PM
dfooch
Aug 24, 2010 10:25 PM
jimnehmzow
Aug 18, 2005 07:49 AM
PsychoBoy1964
Jun 8, 2004 06:06 PM
gamer0808
Nov 13, 2001 10:44 AM
