Bought 3400 4wd Kuboata W/bucket
Received 1,344 Likes
on
Bought a John Deere 755, the power train is from Japan. Seems like a good unit for a 20HP, have only used it for 30 hrs. Have a 5ft mower and a 4ft roto tiller with a loader, it all works good and is a handy little unit. The 3 cylinder engine vibrates quite a bit at an idle but has good power. Seems quite tippy , high center of gravity and the wheels are quite close together. I like it.
When judging tractors it is good to compare total weight and lift capacity, they will usually tell you what the tractor is capable of. I owned a JD750 for over 15 years and sold it and a 60” mower deck for what I paid for the tractor. Not a bad investment but I missed it so bad that I had to buy another one, this time a JD 4200.
on
1 Post
we use my brothers Kubota for tree removal. i cant think of the model #, but its a diesel 4wheel drive with a bucket and forks attachment
the lifting capacity of his kubota is 900 pounds on the forks. we often have to load tree logs much heavier than 900 pounds... so much that we have 2 guys standing on the back end of the tractor to keep the rear wheels somewhat on the ground.
the only parts replaced on it in 3 years is a front wheel seal. im not huge on japanese anything, but they really build these tractors well.
id give your new tractor a few trys, you might get to like it.
spikedog
13
07-03-2008 08:21 AM
