Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Towing with a Lightning
Old 12-17-2004, 11:12 AM
stein78's Avatar
stein78
stein78 is offline
I searched the boards and couldn't find many threads about towing with a lightning. I am looking to upgrade my current truck (daily driver/tow vehicle) next spring and I can not decide what to do. How well does a lightning tow? I would be towing my mustang and open car trailer to the track. Sometimes distances over 6 hours away. I know the towing capacity is 5000lbs, my car/trailer would probably be just over 4000lbs. I also would occasionally tow my dads 23' boat, which probably weights in ~5000lbs. Why is the towing capacity so low? Is it the trans? Tires? Suspension? I was also looking at F250s, but the fun factor of the L really has be thinking. Any input is appreciated, thanks.
Old 12-17-2004, 12:47 PM
nthe10s's Avatar
nthe10s
nthe10s is offline
I've towed with both of my Lightnings. Usually my 87 Mustang on an open trailer, roughly +-5000 lbs. I've towed on several 14 hour road trips. An f250 will tow better because of the heavier duty suspension, and longer wheel base. The Lightning has more than enough pulling power and really does just fine. So as long as you don't buy a Lightning JUST to tow, you will love it. Nothing else I've found can do it all like a Lightning. You can load the bed full of crap, pull your mustang to the track, then uload everything and have a truck that can bust off 12 second timeslips . And do it all easy!
The only drawbacks are- you won't get great gas mileage, but that is true with most trucks. And it drives like a Mustang in the snow. Don't even know if thats an issue for you .
Old 12-17-2004, 01:16 PM
stein78's Avatar
stein78
stein78 is offline
It would not just be my tow vehicle, it would also be my daily driver, but I would be using it to tow quite a bit. I would like to make it to 4 or 5 NMRA events throughout the season and some misc trips to local tracks towing the mustang. I figured it wouldn't do that great in the snow, chicago winters can be pretty bad at times. I think I am leaning towards the F250, but I have always wanted a Lightning. Actually, I have never even had a ride in one or driven one for that matter. Maybe I shoudn't, cuz if I do I think I might be hooked.
xr7gt390
2015 - 2020 F150
116
05-13-2017 11:41 PM
walt460
1997-2006 Expedition & Navigator
15
09-05-2015 01:37 PM
WLD257
06-02-2011 06:59 PM
don7070
19
02-02-2011 10:30 AM
cakewalker
1978 - 1996 Big Bronco
12-02-2001 08:50 PM
Quick Reply: Towing with a Lightning
