View Poll Results: Has your truck had the same problem?
Voters: 19. You may not vote on this poll
F250 Alternator almost burned
After a short drive in my 1988 F250 (302 engine) I saw smoke from under the hood. upon opening the hood I saw that the lower plug into the alterator was melting and smoking. I pulled it loose, and it stopped.
I figured the alternator must be bad, so I got a new one. In the box was a note saying that this very thing has been happening allot, and they do not know why. They said to replace the plug itself (which I have to do now anyway), and coat it with dialectric grease.
My problem is that my local ford dealer says that they don't have the plug, and that they'd have to order the whole harness. They suggested a local (good) parts store, but they didn't have it.
Anyone know of a source for these? It is a 3wire plug
Thanks
Dan
Thanks
Dan
There is a Ford TSB on this very subject. It even mentions a part number for a kit to fix the harness. Looks like you could order the kit and be on your way.
Ford TSB 96214, applies to F150 through F350, model years 1986 through 1994
(The TSB also applies to numerous other car and truck models)
ISSUE:
When a generator fails, there are a few failure modes that may cause heat to be produced at the wiring harness-to-generator connector. This excess heat may damage the female terminals on the wiring harness, resulting in increased resistance. The increased resistance produces more heat. When the generator is replaced, the resistance produced by a damaged connector may damage the new generator and could result in a repeat repair, including installation of another generator. High resistance (caused by a damaged connector) will not go away until the damaged connector is replaced.
ACTION:
Visually inspect the harness-to-generator connector for damage (heat, corrosion, distortion and cracking) before installing a new generator. Install the Generator Wiring Harness Connector Kit (E5AZ-14305-AA) if the harness-to-generator connector is damaged.
The Generator Wiring Harness Connector Kit (E5AZ-14305-AA) contains the following:
^ One (1) Red Wire Butt Connector
^ Two (2) Yellow Wire Butt Connectors
^ One (1) Wire Connector Assembly
^ One (1) Instruction Sheet (I.S. 6849)
ISSUE:
ACTION:
This is an old problem with the second generation Ford alternators. All the parts stores I deal with carry this plug one brand I remeber is Pico. They make this replacement plug for about $9.00. And when I change one I solder and shrink wrap the connections no butt connectors for this. And Ford has been sued for cars burning complete up over this very connection. The third generation alternators do not use this plug for the battery feed. And you can retrofit a third gen to a second gen system with very little effort.
Tectron1 did the 3 gen conversion. These alternaters will fit in the brackets and all you have to do is redo the the big plug to a lug type connection. and then I believe the smaller wire in that plug is the S connection needs spade connector put on it and then plugged into the S connector on the new alt. The two big wires in that connector are the B+ wires and actually tie back togather a little further back in the harness. The only thing you need to watch is the fact that the 3g alt is capable of producing more amps and you might want a little heavier wire back to the Battery.
I know this is an OLD, OLD thread but i wanna bring this back up to the top for future reference for anyone dealing with this. it just happened to me and i almost saw my truck go up in flames. the entire harness from the alternator to the solenoid was damaged.
my fix is to install a 3G alternator with appropiate wiring, fusing and connectors.
i would REALLY appreciate it, if this could be made a stickey or somehow be made into a stickey by editing...this is a common and serious problem.
