Ford or Lincoln C6
on
The C6 internals WILL vary depending upon motor and application. Big engines and trucks run higher pressure as well as a bigger clutch pack.
So for instance a 351W in a car and one in a E350 for instance will be different internally. However it is all bolt in parts and many car trannys got upgraded during a rebuild.
A Lincoln 460/C6 will shift softer than one out of a truck.
You might want to look into your options before you decide to swap internals between transmission cases. Now 460 C6 transmissions are pretty common and are easy to find, and you can usually get them for a reasonable price. Now take your 360 C6, I would think that this is a transmission that is getting harder and harder to find over the years. So depending on the condition of your current transmission, you might be able to make a trade with someone if you really want to go to a 460 C6. Or see if you can core it in for the one you want. The list goes on and on. It makes me kind of wish I didn't get rid of all those 460 C6's I had. I think I had 3 spares at one time. 2 I junked and the third was sacrificed to save a 4X4 transmission with a broken case. Its funny cause I now have an FMX and I cant even give that thing away.
RFAgrasshopper
06-06-2012 08:15 PM
nruggiero
07-14-2010 01:14 AM
scottie2hottie
07-05-2004 08:13 PM
