bad oil pump on 91 f150 with 302
You have to raise the engine or lower the truck. The oil pump is pretty easy. Make sure the edges of the pan are straight and clean before you reassembly. You might want to make sure the passages from the heads are open while the pan is off. Good time to clean things up. Good luck with it.
Harley Hill
11-11-2016 11:25 AM
pcmenten
11-10-2004 03:23 PM
pcmenten
05-14-2002 08:33 AM
