5.4L aftermarket air intake. - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Reload this Page >
Old 12-05-2004, 09:54 AM
Gary42141
Gary42141 is offline
Gary42141 is starting off with a positive reputation.
I'm not talking about the intake manifold.....just the air intake line. Do any of the products such as AirAid give any noticeable improvement in performance?
It'd seem like a straight shot into the throttle body would be better than having the airstream make three 90 degree turns before it hits the throttle body. I've seen some advertised claims of up to an 18 HP increase, just by changing the air intake, and up to 12 HP by adding a 1" helix spacer. Seems a bit too good to be true.
Also... On the stock air intake, does the portion of the intake that sits over the top of the radiator serve any purpose?
Thanks.
Old 12-28-2004, 09:52 AM
ckidd
ckidd is offline
ckidd is starting off with a positive reputation.
Airraid actually claims a really high increase in power. They were supposedly claiming like 38 hp, but I have had a few of them installed at my shop and they didn't make that much of an increase. The one that I have found the best increase in is the K&N. This one actually has like a throttle body spacer in the kit. Plus the Airraid actually has had some problems with DTC codes. They are in some vehicles making the computer say lean.
Old 12-28-2004, 12:46 PM
Uncle Jesse
Uncle Jesse is offline
Uncle Jesse is starting off with a positive reputation.
I think the part over your radiator is a baffle to quiet the air noice. I have an Airaid on my 4.6 liter, and it's a lot louder under throttle, but i did pick a few ponies by my butt-dyno at least...
Old 12-30-2004, 01:31 AM
97Centurion's Avatar
97Centurion
97Centurion is offline
Rub my Belly
97Centurion is gaining momentum as a positive member of FTE.97Centurion is gaining momentum as a positive member of FTE.
As with most after market mods the advertised increase in HP is over rated. IMHO. When I installed my Volant, I noticed a slight increase in mid to upper range HP. I did pick up 1 MPG better fuel milage. I was more exited about that. lol
Jayme Duty
1997 - 2003 F150
32
11-08-2017 03:01 PM
gustrider4
1999 to 2016 Super Duty
06-13-2016 10:25 PM
dunnerjeff
03-23-2015 10:46 AM
MikeZealot
1997 - 2003 F150
11-22-2014 11:51 AM
azcoug
08-25-2003 10:20 PM
Quick Reply: 5.4L aftermarket air intake.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
