i'm sure someone in this forum has experienced this problem. today i replaced my 513 rear axel ratio to a 355. now the speeds are up for the previous rpm ranges. however my spedo does not recognize the new ratio. what will i have to replace to get my spedometer to register correctly.
thanks
john
you will have to get the proper gear for the trans to register properly. At the end of the speedo cable is a pair of plastic gears, they will have to be replaced witht he corresponding ratio for the rear ratio and tires you are running.
