V8 replacing inline 6?
Old Dec 1, 2004 | 05:18 PM
Red96F150's Avatar
Red96F150
is it possible to put a 96 4.3 mustang motor or any other v8 in my 96 F150 that has a 4.9 inline 6? my motor just rolled over 200,000 miles and still runs strong, but when it dies, i wanna keep the truck and put a v8 in it. any suggestions or comments? thanks
oh BTW, nice site. FORDS ROCK!
Old Dec 1, 2004 | 06:05 PM
radramrod2's Avatar
radramrod2
Smile
My thoughts:
The easiest V8 swap would probably be a 302 or 351W. These trucks had them and would bolt right up to your bellhousing.
Is it a manual or automatic?
Old Dec 1, 2004 | 06:26 PM
Red96F150's Avatar
Red96F150
i have an automatic, E4OD, but it will be replaced with something else maybe.
Old Dec 1, 2004 | 07:59 PM
'961506's Avatar
'961506
The stang engine is a 4.6, but i do believe that radramrod is right and it would be a lot easier to swap in a 302 or 351. Whats good is that the 300 will last a while, and if you are in a no smog state, and milege isnt a concern, you can have a sickass engine waiting to be swapped in by the time the 'ol 300 dies. good luck man.
Old Dec 1, 2004 | 09:56 PM
radramrod2's Avatar
radramrod2
Smile
If your E4OD is in good condition, I'd probably keep it in there.
If you're wanting to swap in a 302 or 351W all you need is the complete EFI setup (I'm assuming speed density, mass air is a little bit trickier), the wiring harness for the EFI motor and the computer for the engine WITH the controls for your E40D, automatic and manual computers ARE different. Make sure you get the right one. The proper frame mounts, either 302 or 351W will work for either motor, and the proper flexplate, 302 is different than a 351W. The best thing to find is a complete donor vehicle. It'll have all the "little" parts you didn't know you needed. The proper radiator and exhaust setup will hopefully top it off. I may have forgot something, hopefully someone will chime in.
Hope this helps
Rad
frank_kay1
May 8, 2013 04:06 PM
lemcham
Offroad & 4x4
17
Apr 19, 2007 01:32 AM
slow_v6_stang
General Automotive Discussion
16
Dec 11, 2006 07:57 PM
pikiluvi
Feb 26, 2004 01:13 PM
