need 2bbl carb info
Old Dec 1, 2004 | 08:15 AM
montster's Avatar
montster
need 2bbl carb info
Well I'm looking to start the winter(indoor) project. My truck is a 83 bronco and it is used mostly for trail and mudd offroading. So I would like to put a 2 barrel carb on it, I was told the 2150? was a good choice for offroading but my question is what year make model should I get it from and do I need to change anything else?(dont know that much about all the different fancy stuff ie the funny box on the fender)but I am good at following directions(espesially with pictures ) basically I will either buy a clifford intake or mod the stock and pollish out a set of efi exhaust manifolds, but I need your help with the carb, spark, dist choices( would like to keep it as simple as posible)
thanks for any help you can give
monte
Old Dec 1, 2004 | 01:50 PM
mary-kate's Avatar
mary-kate
Well if you want to keep it simple why not leave it stock? Heaven forbid right But I'm not sure what your asking. Do you have electronic ignition already? does your truck already have a 2-bbl on it? etc. etc. And you said you want to mud/play with it but if your going to settle for a 2-bbl carb, why not just rebuild the one there now or leave everything be?
Old Dec 2, 2004 | 07:08 AM
montster's Avatar
montster
I have been told that the 2150 motorcraft is a very good off road carb for the 300 and yes it is stock now that is why I am looking to buy or fab an intake for the 2 barrel and change the exhaust manifold to a pair of the efi's as to the ignition that is why I am asking, my bronco is a 83 I-6 and I was told to get a 2150 from a 400m but I want to know which year I should look for and what I need to do as far as the ingnition goes.
calazo
30
Dec 8, 2018 11:16 PM
Khauler
Oct 28, 2011 01:54 PM
TheDesertRat
Oct 3, 2011 12:14 PM
heavyb38
Jan 14, 2010 08:34 PM
AZ4x4f150
General Automotive Discussion
22
Feb 8, 2007 02:58 AM
