Hitch and Ball size????
Old 11-27-2004, 04:11 PM
YOMAN
YOMAN is offline
YOMAN is starting off with a positive reputation.
My truck FX4 has trailer tow package included..
I went to Pep boy and staring at few hitch and *****...Heck i dont know which is better suit for my truck F150.
There are few different inches drop like 2, 3.5, 4.5, 5.5 inches drop and ***** is between 1 1/4 to 2 1/2.
I will install autospring sometime soon when i have time... i have FX4 w/ 18" but will swap to 17", 295/70/17 when i have $$
Soo i need your advice, which hitch should i get ? 2" drop?
Big thanks!
YOMAN!
Old 11-27-2004, 04:13 PM
gymrat12
gymrat12 is offline
gymrat12 is starting off with a positive reputation.
2" drop with a 2" ball would be perfect!
Old 11-27-2004, 07:04 PM
ctfordguy
ctfordguy is offline
ctfordguy is starting off with a positive reputation.
Really depends on your trailer. Small trailers under 2000# use a 1 7/8" ball, 2000#-6000# use a 2" ball and over 6000# use a 2 1/8" ball. The drop required is a function of the trailer also, you want your trailer level so depending on height you will need to adjust drop. Most ball mounts are rated for 6000#, so watch for this if your trailer is over 6000#.
I tow a small utility trailer with, 1 7/8" ball with a 4" drop. My travel trailer needs a 2" ball and a 2" drop.
Old 11-27-2004, 08:13 PM
c ball
c ball is offline
c ball is starting off with a positive reputation.
Most trailers ,utility and bass boat trailers take a 2 in ball.I have a 04 supercrew XLT and it took a 3 1/4 in drop to get the trailer level..I tow a 17 1/2 ft Stratos..
Old 11-27-2004, 08:30 PM
tsc
tsc is offline
tsc is starting off with a positive reputation.
I agree with CTFORDGUY. I have three trailers and two of them sit at different heights. (All 2" *****). I opted for a Reese adjusable, to compensate for the height. It was cheaper to buy one ball and the adjustable, then to buy two ***** and two ball mounts. They also make adjustable *****, where, you can change the ball size in seconds. It all depends on the trailer
Old 11-27-2004, 08:33 PM
keith Ruge
keith Ruge is offline
keith Ruge is starting off with a positive reputation.
2 inch by 2 inch has my vote
Old 11-27-2004, 10:01 PM
likalarry
likalarry is offline
likalarry is starting off with a positive reputation.
Originally Posted by tsc
I agree with CTFORDGUY. They also make adjustable *****, where, you can change the ball size in seconds.
I bought an adjustable ball set awhile back..... The thin folding latch that holds each ball in place seemed flimsy at best. Sure enough, the latch failed, and fell off. Luckily, the ball stayed in place, but could have easily have popped off the shaft. Later, the U-Haul guy told me that they've been illegal in California for some time now.
Larry in SF, CA
Old 11-28-2004, 01:31 AM
Dunk's Avatar
Dunk
Dunk is offline
Dunk is starting off with a positive reputation.
http://www.hitchsolutions.com/alumistinger.html Alum ball mounts. No grease, no rust, no mess if you want to take it off and throw in it the truck..
Ct, that bigger ball size would be 2 5/16"...., but the real strenght is in the shaft dia on the ball. Up to 6k 1" shaft is fine, over that you should be using a 1 1/4" shaft ball. You need to buy the right ball mount shaft size to match the ball shaft.
Old 11-28-2004, 09:42 AM
YOMAN
YOMAN is offline
Got it thanks yoman!
ipefjk
2017+ Super Duty
05-12-2017 06:47 PM
Rovernut
All Other Items for Sale
02-17-2016 04:02 PM
YOMAN
2004 - 2008 F150
17
12-25-2010 07:09 PM
YOMAN
2004 - 2008 F150
07-08-2008 07:30 AM
YOMAN
2004 - 2008 F150
07-13-2007 07:23 PM
Quick Reply: Hitch and Ball size????
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
