I have a 01 F-150 stepside shortbed regular cab....it is a 5 spd also with floor 4x4 shifter......i would like to put a body lift on it.....if i put a 3 or 4 inch lift on it what size tires can i fit....and would you recomend putting on the leveling kit also.....i have 16'' wheels....thank you
I'm not sure if it changes anything. The kit instructions should expain what needs to be done. A girl at work has a 2wd 4.2L/5-speed with a 3" body lift. I don't know if the shifter was modified or not though.
