92 F-150 302 EFI spark plug issue? - Ford Truck Enthusiasts Forums
Old 11-23-2004, 10:44 AM
Jrock909 Jrock909 is offline
Jrock909 is starting off with a positive reputation.
Okay I have a question on spark plugs, for some reason last week when I went to buy some ngk spark plugs the threads were not long enough to reach the threads inside the heads, now I finally found some plugs that would fit and thank god they were autolites. I figured I couldn't have NGK's I better get the next best plug and that is autolite plugs with the copper cores to them so the parts lady took about 15 minutes to try to find the right plug for my truck. Why would Ford make different style heads, because those ngk plugs should have fit fine. I tried bosch and they had one style that is called for on my engine, so bosch and autolites had the right style plugs, but I just think it's weird I had to buy a weird style plug to get down there in the heads to thread in??? Any answers guys?
390 farmboy11102 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-19-2016 09:42 AM
66 Ford F100 5.8, which spark plugs do you recommend? jasindude1 1961 - 1966 F-100 & Larger F-Series Trucks 4 05-03-2016 07:19 AM
94 4.0 bogging under throttle JoeNoble Ranger & B-Series 131 12-17-2012 09:51 PM
Best way to change spark plugs KhanTyranitar Aerostar 8 02-04-2011 05:03 PM
NGK - V Power Spark Plugs - Any Good? lt 1987 - 1996 F150 & Larger F-Series Trucks 5 06-30-2002 09:37 PM
Tags
302, 92, bestsparkplugsf150302efi, f150, ford, plug, plugs, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
