Free '90 EFI 351M
Free '90 EFI 351M
I have a 351M out of a 1990 Bronco that is currently on a stand taking up space in my garage, and anyone that wants it can have it FREE!! It may or may not be rebuildable, I took it apart to find out what was wrong with it (it was given to me) and found that the cam broke and when it did a piece of it got caught up in the crank and took a small chunk out of the #1 cylinder wall. It looks like the chunk is below the lowest point of compression. The engine is complete with all the intakes & exhaust manifolds, all the fuel injectors, throttle body, (I did break the EGR when I was taking it off), there is NO starter. If you want it you can have, if you want the stand too that is going to cost you $40.
I would like to just strip it down and use it for parts, but I've got a 302 so most of what I would want wont fit.
I live in Northern Utah County.
First Come, First Served.
Thanks,
Longneck
Thanks,
Longneck
