'88 Ranger Pops Out of Gear - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-12-2002, 09:30 AM
Ray R Ray R is offline
Ray R is starting off with a positive reputation.
Howdy folks. I have a '88 Ranger 4x4, 2.9L, 5-speed (Mitsubishi tranny, I think) that has recently developed a quirk. It pops out of fourth gear at steady speeds. It's just fourth gear, and never under accelleration. It does it primarily when letting off of it and coasting to a stop sign, etc. It's never comes out violently and goes right back in pretty easily. Almost seems like the shifter is kind of loose or something and the boot is pulling it back out. I figure if this were the case though, it would do that in second as well. Not sure on that one. Anybody have any ideas on what my problem may be? I should add that the truck has about 150k miles on it and the tranny is beginning to make a little bit of bearing noise. Am I looking at needing a rebuild soon? Any suggestions would be helpful and appreciated.
Thanks in advance,
Ray
Old 03-15-2002, 08:54 PM
BLOWNRANGER BLOWNRANGER is offline
BLOWNRANGER is starting off with a positive reputation.
My '88 Bronco II developed the same problem with 1st gear, I think it was. Simple fix there. New synchronizer. Same symptom as yours. Have them throw in all new synchs and a clutch and bearing while they're in there. That'll save money down the road.
Old 03-15-2002, 10:36 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Tags
gear, pops, ranger, speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
