#8 injector, you're outa' there! (cackle)
So, I went to the dealership and talked to the diesel tech there and he said that with the infamous cackle, or knock-knock-knock at idle like a hammer to the block sound, that there is a way to fix it. Since I had been told by another dealer that this was normal and get used to it, you can imagine my happiness.
Anyways, he said that the way to fix is to order a new injector from Ford that has a higher volume of oil and that way it will have enough oil at idle and not be starved by the #6 injector. He said that 100% of the time it fixes the darned cackle sound. Now the good news is that Ford warranties this if under 100k 5year with $100 deductible. I am at 99949 and they just laughed. A couple more miles and that injector would have cost me around $650 ! I am posting this because I know that the cackle bothers me quite a bit and I'm sure there are more of you out there. Hope this helps anyone with this problem, I will post the results next week when it gets fixed.
Hammer
I second that. I would be very hesitant to install a Long Lead injector. IMO all that is going to do is to give an unbalanced fuel delivery to the engine.
I highly suggest going to www.texastowncar.com and reading about thier research and developement on the idle knock and diesel cackle.
Also the real cause and cure can be seen in the pictures here: http://community.webshots.com/album/32614313yLKyrS/0
Also there is this: https://www.ford-trucks.com/forums/s...d.php?t=260173
Why is this a crappy fix? it seems to me that if the knock goes away, it would be fine. Forgive me I am new to diesels but if they say it is common and that it will fix it, why wouldn't I do it? I really like the idea of the fuel mods you guys mention but don't have the time or a garage door tall enough to work under the hood of this beast. $100 bucks to make the knock go away seems great to me. I will see what else gets posted this weekend before I take it in to have done. I really respect your insight, Thanks
I am really looking for any help and advice I can. I know I am not the only one that hates the knock. I was just driving today with a customer of mine that asked what that sound was. It made me think that it is pretty bad if an average guy hears it in the cab. Also the diesel tech comes highly recommended by several others and had the knock on his truck and it went away. So, not looking for any arguments, just advice. Thanks all-
Too Late??
Hope its not to late to add to this post. Is all this information on fuel tank mods, hx hose and return line regulator for the newer PSD's? I have a 96 that I got about a month ago and have spend a lot of time reading on this great site but it seems to me that the year spread on PSD's is to big. Just wondering, I would like to try these mods!
I am not sure about this but I think all you need to do, if you want to do anything is the HX hose.
'99 and up have a returnless fuel feed to the cylinder heads. >ANY< air, bubbles, gasses that end up in the fuel rail must be injested and injected into the engine to get rid of it. Your's has a fuel return so that's not an issue with your engine.
Diesel Manor sells the HPX:
http://www.dieselmanor.com/default.asp
Dennis sells a complete kit for the tank and pre-pump mod and the (JNB) Gen 2 Regulated Fuel System:
http://www.itpdiesel.com/
