Constant or Variable Coil Spring?
Old Nov 17, 2004 | 10:18 PM
Arrow201's Avatar
Arrow201
Hello,
I'am going to purchase new coil's for my truck (1976 F-100, 360 2wd) when i redo the bushings this winter. I went to a parts shop and priced coils. The constant rate coils are 100 dollars canadian, while the variable coils are 200 cdn dollars. The parts guy said that the variable rate that has varying spacing distance between the coils and gives a superior ride.
So my question is how much better is the ride with the variable over the constant and is it worth the extra 100 dollars? I am willing, although relutantly, to spend the extra cash if it is worth it.
The truck is simply used as my summer driver, does not pull extreme amounts or that often. I just want a good handling/driving truck.
Thanks,
Rod
Old Nov 18, 2004 | 12:21 AM
79 Trailer Special's Avatar
79 Trailer Special
I have seen many people who went with the variable coil and they all ended up with the same problem. The top few coils are whats different but what happens is they end up drooping or in other words all the variable coils end up sitting on top of eachother negating the variable effect.
Wish I knew of a set that actually worked.
Old Nov 18, 2004 | 04:48 AM
SRD4X4's Avatar
SRD4X4
I've been using MOOG steering/suspension parts for years with no problems.There variable-rate springs are called cargo-coil.But with what you do with truck,just replace with regular springs.
Brandynr
Aug 21, 2016 08:24 PM
uncleshepard's69
May 18, 2016 10:47 AM
Firefighter 1406
Mar 31, 2016 04:39 PM
Boba Fett
Jul 11, 2014 11:10 PM
vacman
45
Sep 15, 2012 07:05 PM
