02 F250 SUB Enclosure
Has anyone put a box with 1 or 2 subs in an extended cab 250? Im trying to find someone to squeeze some in here without giving up one of my seats. Under the seat is what Id rather do. Let me know if anyone has done this before please along with what you through in there.
fab150, I put 1 10" in mine and it sounds awesome. Went with the Q-Logic custom box. It fits partway under the middle of the back seat and comes up like a center console. Even has 2 cupholders in it. And if you turn the stereo up loud enough, it'll mix your drink for you. You might be able to see a bit of it in my gallery pics. Here's a link off of crutchfields site: http://www.crutchfield.com/S-6xuliAAYZ1X/cgi-bin/ProdView.asp?g=182750&I=044CFSX056&search=q%2Dlogi c
ktm- Check my gallery for amp location. I had to cut a bit of the frame out of the backseat but it works perfectly (and doesn't overheat).
Good luck
Good luck
2000silverbullet, Thats a good looking truck man. I cant believe that amp dont overheat. Its a good idea though I might have to try it. Probally have to squeeze a fan somewhere since Im running a RF amp. In your enclousure where is the sub at. I think Im gonna try to build something like that. Maybe a center console like one for the back. How wide is the enclosure and does it go all the back under the seat? Another ????? why didnt you like the PJs? That is what I was planning on running. I had the SSR 37s on my f150 so if you could compare them to those if ya need.
matt
Originally Posted by KTM520guy
I have the 60/40 rear seat. The box when built should not stick out past the seat. I saw a pic on the net of a box and decided to copy it. We'll see how it turns out.
My one big amp will not fit in the cab so I'm doing two smaller amps.
That's a neat looking install. I might have to try it. Is that PPI amp fan cooled? I have a Soundstream VGA800.5. It's almost that big. I have the option of running it or two small RF amps that I have.
I'm still in the planning stages of my install. How/where did you run the power cables into the cab?
It's not fan cooled, it's el natural.. ha ha. I'd go with the big dog amp if you could get it to work.
I ran the power wire down the passenger side up under the firewall. If you look up against the firewall, you'll see a big grommet in there (assuming you have a SD). Cut a hole in it and shove that cable through.
The best thing to do (and this is what I did) is rip out all the seats and the carpet. It's so much easier in the long run when you're trying to move around in there. It's a bit more work but it makes the install cleaner and quicker. I ran the rca's off my head unit straight down the center of the cab (taped periodically so they wouldn't move around). The ground is grounded to the seat belt anchor in the back seat.
KTM - I didn't think I could fit that amp in there either, but I kept looking at it and thought it HAD to fit somehow. I didn't end up having to remove much of the frame, just the center portion of it that rests against the body of the truck. What I did was pull the seat back off, bolt the amp in and then hold the seat up against it and mark where to cut the frame with a black marker. Get out the grinder and just start chopping away. Nobody even notices when they're sitting back there and it feels normal when you lean back against it. I do plan on putting some fans in there eventually, but now with winter here, I'm not going to worry about it.
FAB- Not sure what you mean. Are you asking if you could mount the 10 sideways on the box instead of facing down? Let me know.
That is what I was asking but I dont need to know anymore. I started builing mine today. Looks just like the q-logic almost minus the cup holders and its made of MDF.
I got all my pieces cut today but i ran out of battery power so it will be finished up tomorrow. Im not sure if I am gonna try the amp where yours is or just put it under a seat or something. Im really glad you had a pic of that enclosre up man. It should work quite well. I am putting my 12" Diamond Audio M6. Hopefully it will have enough airspace. I cant figure out the volume with all the trapazoid looking thing. Guess I shoulda paid some attention to the geometry teacher.
