Error Code 157...help
Old Apr 15, 2002 | 11:26 AM
Gman2160's Avatar
Gman2160
Post Error Code 157...help
94 Ford Ranger, 4.0, 5spd. Started stumbling occasionally, (1 week
after I bought it used), then check engine light would come on. After
a few minutes the light would go off, run good for a min, stumble,
light come on again, then start cycle again. Tester checked 111 for
current, 157 in memory. Took MAF out and cleaned it, still the same.
Actually, I got 157(maf low voltage) and 158(maf high voltage) before
I cleaned it, now I just get 157 (progress?). Cleared the memory, 157
comes right back. Do I need new MAF Sensor, or somewhere else to
check first?
Thanks
Old Apr 15, 2002 | 08:56 PM
Ken00's Avatar
Ken00
You could run the pinpoints tests to determine the exact cause but you will need a breakout box to test the curcuits, I have the tests.
Old Apr 15, 2002 | 11:03 PM
aksniper's Avatar
aksniper
hunter29078
53
Oct 10, 2015 12:37 PM
dlmoye
Jun 9, 2012 04:36 PM
93Pepe
May 10, 2012 06:50 PM
Snoopdale
Apr 7, 2012 11:18 PM
moat
Aug 17, 2005 05:15 PM
