Tail gate latch ajustment?
Old May 26, 2002 | 09:37 PM
Sawbones25's Avatar
Sawbones25
Old Jul 1, 2002 | 03:20 PM
formermustang's Avatar
formermustang
Any one out there had a problem with one side of the tail gate latch not catching? The driver side catch needs not even a 1/4 inch further out and I maxed out the adjustment on it!!! It might be the stop on the catch, but I don't want to beat on it untill I find out if some else had the same problem!!! Thanx
Old Jul 2, 2002 | 12:54 PM
Ken00's Avatar
Ken00
Are you sure it's not the linkage in the gate holding the pin in or maybe the bed is not aligned/square?
Old Jul 3, 2002 | 04:15 PM
formermustang
I figured it out on further inspection. I moved the latch into the catch with a screw diver. So I droped the tail gate down to discover both the latches are TOAST. They wiggle about a 1/4 inch or so. Not the whole assembly, just the little part that goes in and out from the handle being pulled. Hopefully I can retrofit a little plastic shim that goes behind it, if not, off to Ford I go!!! Thanx for the input though!!!
