3.00 gears
Old Nov 4, 2004 | 04:31 PM
ford390gashog's Avatar
ford390gashog
3.00 gears
what is the point of having 3.00 gears in a ford 9'' the came stock and the diff is all original
Old Nov 4, 2004 | 04:41 PM
maverick man's Avatar
maverick man
my 75 has 3.00 gears and I would raise the same question. with a big block it doesn't take much to launch it though. it probrobly has something to do with keeping the rpm's down for gas mileage.....
Old Nov 4, 2004 | 04:43 PM
73Custom's Avatar
73Custom
The idea was to get a higher rear gear for better mileage on the highway. Some pickups had even higher gears - 2.73 or so.
Marty
Old Nov 4, 2004 | 04:46 PM
ford390gashog
my gm friend was arguing with me a said a 4.10 was a higer gear than a 3.00 i couldn't beleive how stupid he sounded.
Old Nov 4, 2004 | 05:41 PM
theonlybull's Avatar
theonlybull
your friend is correct, 4.10's are numerically higher reduction, which is how ratio''s are supposed to be referred to.
Old Nov 4, 2004 | 06:21 PM
Rifleman7.62's Avatar
Rifleman7.62
Yep, those GM guys will do that.
I got 3.00 gears in my 79 F150 4x4. The only thing I don't like about it is that you can't run tires of any decent size without burning the clutch out in a hurry. I getting som 33's and that'll be pushing it.
Old Nov 4, 2004 | 07:29 PM
cannonfodder's Avatar
cannonfodder
3:00 gears and 33s = burnt clutch. You're right You needs some 31s or 4:11s. Don't nit pick me on the ratios boys
Old Nov 5, 2004 | 07:39 AM
bremen242's Avatar
bremen242
3.00s are great for a stock 300-6 with 29" tires, you need something deeper for anything else.
Avanti
May 4, 2005 01:06 AM
ford390gashog
Oct 21, 2004 07:26 AM
ford390gashog
Oct 17, 2004 12:22 AM
williso
Mar 18, 2002 01:06 AM
