1983 Ford Ranger Diesel bad fuel mileage - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Reload this Page >
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-31-2004, 09:30 AM
rkim777
rkim777 is offline
rkim777 is starting off with a positive reputation.
Hi, all. Newbie here. I recently bought a 1983 Ford Ranger Diesel pickup truck (2.2L Mazda engine, manual transmission). The dealer said to expect a little above 30 mpg on fuel mileage but the two fill-ups I've done show an average fuel mileage of 22 mpg. About half of these are highway miles.
I thought diesels are supposed to have good mileage. Is this typical for my year and model truck? Is there any way to increase the mileage? I just replaced the air and fuel filters and also changed the oil and oil filters. If anyone has any experiences with this, please let me know. TIA.
Bob
Old 10-31-2004, 07:43 PM
Ken00's Avatar
Ken00
Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Welcome to FTE!!!
I'm not familar with the diesel's mileage, does anyone have any ideas???
Old 09-18-2011, 11:15 PM
herpelmike
herpelmike is offline
herpelmike is starting off with a positive reputation.
May try a fuel additive called power serve it cleans the injector and lucas upper cylinder lube.
1998 5.4l 4x4 expedition
1983 2.2l diesel ranger
Old 09-19-2011, 01:09 AM
rkim777
rkim777 is offline
Thanks, herpelmike. I'll try it out.
Wow! Didn't expect a reply from anyone 7 years after I first posted this! I still have the truck and it runs well. I was told by a mechanic that the engine will probably outlast the vehcle body!
Bob
Old 09-22-2011, 12:10 PM
montana_highboy
montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
Bob
Did you ever get your fuel issue resolved? these 2.2's should be good for at least 33-38mpg. Your mechanic's correct, the Perkins/Mazda diesels will easily go 500,000 miles plus before a rebuild, i've owned one for 15yrs now (shameless pic below), check out the following link, most everything you need to know about these rare trucks is here.... mazda diesel - Home
1983 Ranger w/2.2L Perkins diesel
Old 09-24-2011, 10:42 PM
herpelmike
2.2l perkins diesel
Havent had a chance to check mpg on my ranger just bought it for 1k. Has 139k on it and i've put 171miles on it. It hasnt been run alot in the last 5yrs.
Michael Shane McDonald's Photos | Facebook
Old 09-26-2011, 12:54 PM
montana_highboy
You did good for 1K, 2.2 Diesel Rangers in good condition with low mileage like yours easily bring in 3K plus on ebay.
Old 09-27-2015, 12:13 AM
62FE4x4
62FE4x4 is offline
62FE4x4 is starting off with a positive reputation.
Fuel mileage
My 85 Ranger 4x4 has the diesel. It has always averaged 35mpg.
Old 09-27-2015, 07:07 AM
tempforce's Avatar
tempforce
tempforce is offline
tempforce is starting off with a positive reputation.
depends on the load, road conditions and your speed.
on flat highway doing 65-70 my ranger averages mid to low 30's. at 45-55 I'm around 40 mpg.
loaded pulling a full trailer 22-24, @65 mph.... in town it varies..
remember these trucks were geared for a 55 mph speed limit..
my truck is getting close to 300,000 miles on the engine. i'm on a third transmission. i found out that running the engine at lower rpm's kill the transmission input shaft bearings. a friend on another web site. had over 750,000 miles on his mazda before dropping a cylinder. cost about $2200 to rebuild his engine.. he was towing in overdrive in the mountains. his engine had a turbo on it, with no waste gate... over 40 lbs boost.. if you decide to clean up the exhaust, keep your boost below 5 lbs. keep the stock injectors...
ps:the photo was taken while i was living in sw oregon
Old 10-06-2015, 09:33 PM
NCMillwright's Avatar
NCMillwright
NCMillwright is offline
NCMillwright is starting off with a positive reputation.
all cylinders punching air and fuel?
superduty bob
1999 to 2016 Super Duty
23
09-27-2017 08:27 AM
Cory Barrow
07-17-2017 12:29 AM
ehaiss
1997-2006 Expedition & Navigator
05-09-2017 06:58 PM
Bradly Stevens
16
02-01-2017 11:42 AM
Fordteamone
Ranger & B-Series
12-14-2015 06:59 AM
Quick Reply: 1983 Ford Ranger Diesel bad fuel mileage
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
