WHAT WEIGHT OIL ARE YOU RUNNING IN THE FE's - Page 5 - Ford Truck Enthusiasts Forums
View Poll Results: WEIGHT OIL ARE YOU RUNNING IN THE FE's
5w20
2.12%
5w30
5.51%
5w40
2.54%
10w30
27.54%
10w40
21.19%
15w40
11.86%
15w50
2.12%
20w50
16.10%
30w
10.17%
50w
0.85%
Voters: 236. You may not vote on this poll
  #61
Old 02-16-2005, 02:49 PM
Annihilator
Annihilator is offline
Annihilator is starting off with a positive reputation.
J&B, what type of engine, how many miles, and when and what RPM does it make the noise? You might want to fix that ASAP... My second 390 (first in the 73, it was the one that came in the pickup) was quiet and clean the day I bought it, the next day it had what sounded like a clatter at about 1400 RPM. Drove it that way till the late the next fall at college and tore it down. The noise was getting more constant and in more of the rpm's. Glad I did it to! I had a rod bushing work loose on the #7 rod and it was allowing the piston to rock side to side. Thankfully it didn't cause any wear in that cylinder but if I had kept driving it that way it would have eventually scattered and proably ruined the block and rod if I was lucky, possibly would have taken a head or heads, and crank among the more expensive things. Just a thought.
  #62
Old 02-16-2005, 03:49 PM
bryyce62's Avatar
bryyce62
bryyce62 is offline
bryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud of
Motorcraft 15-40. I like the detergents of diesel oils for my dirty old 390.
  #63
Old 02-16-2005, 06:50 PM
J&B
J&B is offline
J&B is starting off with a positive reputation.
Annihnlator , 390 , miles only God knows . to my belief it was rebuilt 2 yrs. ago and then sat for 2 yrs. before I bought it . lot of nice equipment on it .
I know it sat because I found bird nest in the duct work . ok , I believe past owner did not go to ,to much trouble when he decided to start it again . I've changed rod bearings , some good some worn . the knock is at idle coasting across the parking lot . the engine is tight , 20 inches of vacuum at idle and 55 lbs. of oil pressure cold , 40 warm . from past research and reading books , I guess 390's are notories for wrist pin knocks if not done just right . they say it should last . I hope , cause I have no garage to pull the motor . the only problem is , not being sure , I'm afaird to go too far , I hate break downs but a ford has never done that to me in 35 years .
  #64
Old 02-16-2005, 09:09 PM
Annihilator
I have never heard of FE's being notorious for wrist pin knock but if there is one problem prone area on an FE, then rod bushings can come loose if not done right. But all in all I don't think it is extremely common. If your a gambling man, you may be allright but who knows, I would try to find a mechanic that has a lot of experience with FE's and Fords in general as they have a tendancy to be a little quirky.
  #65
Old 02-16-2005, 10:40 PM
"Beemer Nut"
"Beemer Nut" is offline
"Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE."Beemer Nut" has a good reputation on FTE.
Lucas for wrist pin knock?
J & B if you need "Lucas stabilizer to help wrist pin knock" you have a sick engine and your fooling youself and wallet that different oil or "additives" will patch your problem. Use some "gray matter". Sorry to sound harsh but people who belive in Lucas products keep Lucas in business. Like power steering troubles, added Lucas and it takes one finger to steer, before it took three WWF people to turn the steering wheel. Bull s**t. Like Lucas stop leak sealer, when the solvents that swelled the seals boil off, the leak will be worse. This is ok for a quick sale to a sucker but not for a keeper.
Carl....=o&o....
  #66
Old 02-16-2005, 11:38 PM
J&B
J&B is offline
Carl....=o&o....
Beemer , the stabilizer is not for the knock but for the oil . as you know , I'm sure , is that multi-viscosity oils have additives which cause the oil to break down sooner , also I live in a high humidy climate . I am only using the multi-viscosity for the cold weather start ups . tried all the other combo's of oil and this one seems to work the best until I can pull the motor for further research . " gray matter " ? non-potable water ? no thanks , that is not compatable with oil
  #67
Old 08-09-2005, 02:39 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is online now
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
most single weight oils use the cheap basestock.
  #68
Old 08-09-2005, 08:32 AM
cyberrich
cyberrich is offline
cyberrich is starting off with a positive reputation.
Castrol 10-40 in my 390 just becuse my machiest told me so.
  #69
Old 08-09-2005, 09:59 AM
bshackelford711
bshackelford711 is offline
bshackelford711 is starting off with a positive reputation.
I live in eastern North Carolina.
our summers get up to 100 degrees
our winters get down to 0 degrees
Which oil should i use in my 390.
i know you guys told me to use Rotella but what weight?
-Brandon-
  #70
Old 08-09-2005, 01:06 PM
ford390gashog
if its hot in the summer i would run any good 15w40 and in winter i would run a 10w30 diesel oil.
  #71
Old 08-09-2005, 11:01 PM
sneak's Avatar
sneak
sneak is offline
sneak is starting off with a positive reputation.
15w40 Shell Rotella T
  #72
Old 08-10-2005, 12:56 AM
ford390gashog
i noticed that with a 15w40 my mileage went down almost 3 mpg and it was very sluggish.
  #73
Old 08-14-2005, 09:26 PM
charles jones
charles jones is offline
charles jones is starting off with a positive reputation.
Uniflow 20-50 Its got 124K on it and in this texas heat my pressure is fine hot or cold.
  #74
Old 08-17-2005, 03:23 PM
ramtoo
ramtoo is offline
ramtoo is starting off with a positive reputation.
I also live in Texas, 20-50 untill it gets cold for 2 month the 10-30
  #75
Old 08-17-2005, 06:56 PM
Madmike33's Avatar
Madmike33
Madmike33 is offline
Madmike33 is starting off with a positive reputation.
Castrol 10w30 in the 360
Quick Reply: WHAT WEIGHT OIL ARE YOU RUNNING IN THE FE's
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
