coil reistor
Old Oct 27, 2004 | 11:55 AM
tb123's Avatar
tb123
coil reistor
87 f150 I6 has anyone ever had problems with the coil resistor [still not starting] ford lists it but says it's not available can I bypass it to check it out or will I do more damage ie to the IDM?"
Old Oct 27, 2004 | 07:52 PM
mhg's Avatar
mhg
to check the resistor use a volt meter
one lead to the + on coil and the other lead
to ground. should read about 8 volts
