Tube frame: round or square?
#31
Yeah but this shouldn't be an issue if your bender is setup properly. As long as you're not collapsing the tube, or flattening it out you shouldn't have any problems with strength. And for those who screw it up they probably shouldn't be building their own cages/frames anyhow.
Round tubing has the same strength in all directions whereas square or rectangular tubing does not. I worked for several years building tri-legged towers. They're always built with round tubing to withstand pressure and twisting from all directions as well as supporting several thousand pounds in compression.
#32
Originally Posted by monsterbaby
if it's not bent correctly...
AXracer
12-02-2014 11:43 AM
AXracer
19
12-04-2013 10:48 AM
blue68f100
08-20-2007 01:04 PM
