2.8 vs 2.9
Old 10-25-2004, 11:43 PM
oldhalftons's Avatar
oldhalftons
oldhalftons is offline
2.8 vs 2.9
what are the difference between the 2.8 and the 2.9 V6?
Is it true that they are the same block?
Old 10-26-2004, 12:41 AM
aahomerepair's Avatar
aahomerepair
aahomerepair is offline
2.8 vs 2.9
yes they are the same block but for some reason you can use the 2.9 heads
on the 2.8 but not 2.8 on 2.9 due to the fuel injection i think the intake ports are different
Old 10-27-2004, 10:34 AM
mrshorty's Avatar
mrshorty
mrshorty is offline
The biggest difference between the 2.8 and the 2.9 is the 2.8 is carburated and the 2.9 is fuel injected.
Old 10-31-2004, 09:30 PM
canzus's Avatar
canzus
canzus is offline
Not even close guys, the 2.8 is a close relative, not a twin,
to the 2.9. For one thing, the 2.8 has a gear driven cam,
where the 2.9 uses a timing chain, the 2.8 heads have a
different intake/exhaust pattern, and the cams are different
because of this... So the only major items that will swap
between the two are the crank and the bell housing...
SteveL
Old 11-01-2004, 12:03 AM
aahomerepair
WHAT YOU SAY ON THE HEADS!!!!!!! what ever
Jim Luff
Bronco II
10-24-2016 12:00 PM
Avtoportal Ukraina
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
05-14-2016 11:40 AM
lwcassady
03-25-2005 09:44 AM
zzrich
Bronco II
08-24-2003 12:18 PM
Slider28
Bronco II
03-23-2002 06:55 PM
Quick Reply: 2.8 vs 2.9
