What kind of seats have you installed in a 65?
I have a 65 F100 Custom cab, and would like a better seat than stock. I have seen the Steel Horse aftermarket seats on eBay and Summit Racing, expensive but nice looking. Has anybody tried those seats, and were they worth the cost and effort? Does anyone have any other seats that they installed that worked well?
Thanks,
Djshoser
Thanks,
Djshoser
Since I don't have in cab fuel tank, mine is split back bench out of a 1977 Ranger XLT
Super Cab with Cloth Covering. It's sits on pair of standard cab (opposed to S/C) seat tracks, all work from 65 thru 79 std cab.
I crowd in 4 people, ride with 3 easily and 2 people have all the room in the world. Behind the seat is storage & tunes etc. I can tilt the pass side back forward when I'm alone to access what's behind there.
I don't have any $$ in that set up. I wouldn't change it for anything. I have power buckets in my T-Bird & my wife's Van, but I like comfort & support a XLT seat provides me and I can ride all day without fatigue or distress. . . .
FBp
FBp
Used 68 seat, as FBp indicated same trac's as 65, slightly wider and Ford went to using bolts to secure back section to bottom. Found it allows for more options. Found 86 seat, which has the folddown arm with coffee holder, and swapped it with the 68 back. Took 86 bottom padding, with the contoured molding, and place on 68 bottom frame. Sets lower, and preferred the contoured molded seat. Located reasonable shop who reuphostered for $300. I found it too difficult modifying 65-79 trac's to later model bench. If recall paid about $100 for the 68 and 86 bench seat. If you came across bottom of 68-79, and back of later model in same salvage yard, which is unlikely, could same some money by making swap in yard.
May sound more involved than it really is. Anyhow, another option to consider. Good luck.
dave
dave
I was not successful getting the 65 trac's mounted on the 86 bench, which is why took the 86 back, and swapped it with the back on the 68. If find the 68 seat too high, should be able to remove some padding to desired hight, or as I had done, took the padding from the 86 and had it installed in the 68 seat frame. This is what like best about the FTE forum, so many different options, or ideas.
dave
dave
I put honda civic seats in my 65. That was pretty rough, as the two vehicles are very different beasts. I took some floorboards out of an acura integra and just bolted them down for the front and door sides of the seats. The inside rear mount bolted nicely to the (stock?) seat belt bolt hole with a little clearancing for the in-cab tank. The seats have built in seat belt buckles, so I still have to install the civic seatbelts. These seats sit a good couple of inches higher up than my bench did and the huge oem steering wheel almost touches my thigh. The drivers seat moved a little toward the center so the wheel is more to my left and the stick is a lot closer than it used to be. I'm a tall dude so the height works out well for me, and the difference in seat position is just great, it makes the driving a lot more frendly. The headrests on the seats go right in with the contour of the rear window. It's a good mod. Now I have room for a center console too! I just got to grind it up and paint it now. Oh and install the belts.
-sam
-sam
I'm with cs65 who is looking for a stock seat. I wouldnt trade my nice springy 65 seat for any modern day overkill. Seems like that would ruin the whole feeling of the vintage. I know a lot of folks enjoy customizing and thats fine. Then there are others like me who keep it stock as I can stand it. I may put a radio in mine. I would be OK with a stock AM-FM if they made one for trucks in 65. Did they?
Hey upgrade crowd. Send me your old junky stock radio and I'll send you an AM-FM CD player!
Don't believe 65 Ford truck came w/ am-fm radio. Admire purest who maintain these rides in original condition. Difficult to find them anymore. Drove my 65 for past 25 years before making any upgrades. When you get to my age p/s, pb, and little bit more padding for the back side is comforting. Also has am radio, do not want to cut into dash, but strickly for show. Not able to pick up but couple am stations. Considering installing sys. in glove compartment.
dave
dave
K.i.s.s
I kept my stock bench seat, just recovered it in a two tone matching vinyl pattern. My 65 custom cab is all original except for a holley 4 bbl carb, American Racing rims, and a CD player. I've been working on painting the engine old Ford blue, the next project will be fix up some rust spots around the door. I really like the way it drives (352 with power nothing-brakes, steering, or tranny!)
Originally Posted by camperspecial65
DJ, what color/condition is original seat in...Im looking for a decent original seat for my 65
Let Me Know, cs65
Let Me Know, cs65
CS65,
My seat is original, although it had a cover put on a while back. The threads are showing through, and I'm pretty sure the seat structure is fine, I have driven a few times with it and it is fairly comfortable. I am looking for something a bit more modern. I will upload some pictures of the truck and my progress as soon as I can, and will upload the seat pictures if you are interested. I live in Northern Cal, SF Bay area.
I have (4) 1963 Falcons I am working on: 1 Convertible Sprint; 2 Sprint hardtops; and one Futura Hardtop Race Car. I guess I'm kind of addicted to those old Fords. I thought this 65 F100 would look very cool towing my 1963 Race car to the track, and it may become my daily driver. I plan to paint it in the next month or so, it is originally baby blue, and I am thinking of tourqoise and white. I always liked that combination.
Dave
djshoser
Let Me Know, cs65
Dave
djshoser
Let Me Know, cs65
