factory overdrive in 1970 f100 302 3speed
Old 12-09-2004, 09:25 PM
Fordknut
Fordknut is offline
Fordknut is starting off with a positive reputation.
If you have a "built-built" 302, you shouldn't be wasting your time with the older 3 spd w/OD tranny. You can not make optimum use of the high performance engine with it. IMHO, you need to be investing some money in a "world class" 5 speed!!!
Old 12-15-2004, 01:11 PM
zebrastud57
zebrastud57 is offline
zebrastud57 is starting off with a positive reputation.
overdrive transmission
to sanmanjoey, i would like to buy that transmission you said is for sale, let me know, [email protected]
Old 03-05-2008, 09:29 PM
lb,douglas
lb,douglas is offline
lb,douglas is starting off with a positive reputation.
Question 1973 F100 engine swap
upgradeing from the old tired factory engine would like to install a newer engine mayby a 2000 to 2005 4.6L or larger newer engine. First is it possible and other than all the sencers and wireing plus computer what woeld be needed. anybody got any info thanks in advance if your willing to give it.
Old 03-06-2008, 02:51 AM
60F100
60F100 is offline
60F100 is starting off with a positive reputation.
Originally Posted by jakon
Ford made a toploader 4-speed that 3rd gear was actually 1:1 and 4th was an overdrive. Very rare, though.
I did not know that they were rare. I have one I picked up in a trade that came out of an early 70s truck but haven't decided what to do with it. Maybe put behind a small block in my 55
Old 03-06-2008, 03:11 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Originally Posted by lb,douglas
Im sorry if ive caused any confusion between my first post and my last. I have a 70 model f100 with an aparent factory 3speed od. I was trying to find out how common they were and what type,I have either a heavy duty or a light duty . Then i ask if it would hold up to a Ford motor sports 302. Built when i say built i mean built.
Borg Warner T-85N overdrive.
Optional on 1965/71 F100's with 240, 300 I-6's and 352/360/390 engines. 1969/71 F100 302.
Passenger cars with 352/390's offered the same O/D trans from 1961 thru 1967.
The T-85N is an excellent transmission, and will get over 25 Highway MPG in the right conditions. 20-22 Highway MPG is the norm.
Issues: The parts are mostly obsolete and are hard to find, both internally and externally.
I wouldn't suggest anyone speed shift a T-85N, but to be realistic, I wouldn't suggest anyone speed shift any Ford 3 speed...except the old Zephyr 3 speed transmission, which was just about bulletproof.
Old 03-06-2008, 07:50 AM
wizzard351's Avatar
wizzard351
wizzard351 is offline
wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.
the top loader looking 3sp OD could be found in of all places a granada from the mid 70's. a few years back they wernt that hard to find but now im shure it be like finding a needle in a hay stack. i still have 2 of them but im shure there coverd up way back in the barn
Old 03-06-2008, 08:02 AM
NumberDummy
Ford refers to this floor shift transmission as the Ford RUG SR-OD Single Rail 4 Speed Overdrive. First introduced in 1977 on the Ford Granada.
The 3 speed Borg Warner overdrives had the shift lever on the column. The trans is a side shifter, and first gear is non syncro.
Old 01-27-2019, 12:25 AM
hooterville
hooterville is offline
hooterville is starting off with a positive reputation.
Hello sir, do you have 3 speed poverdrive transmission for sale? I am in need of that and various parts that you will include. Thanks hooterville.
Old 01-27-2019, 11:19 AM
hooterville
15 years ago you posted trying to sell a Borg Warner T85 R11. I really need a usable one. Thanks alot.
Old 01-27-2019, 12:10 PM
hooterville
I would like to talk to you about your borg warner t85 r11 transmission. I need one. Thanks much.
Old 01-27-2019, 12:48 PM
NumberDummy
I wasn't an FTE member 15 years ago, I joined in 2006. I do not sell parts, so have never had an O/D trans for sale.
1970f100gm
New Member Introductions
03-29-2016 08:27 PM
dthomas620
16
03-15-2012 04:49 PM
speedking390
11-27-2011 01:30 AM
1970xlt
09-28-2002 10:23 AM
speedking390
09-23-2002 01:28 PM
Quick Reply: factory overdrive in 1970 f100 302 3speed
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
