how hard is it to change the ignition switch
Ignition switch
I;m not sure if the truck is like my mustang but the ign. switch should have a little hole in it if you put the key in the switch and turn it to the on postion then put a paper clip in the hole and turn the key back the whole key assembly will pull out then you can oil it with a light oil such as oil for a fishing reel or sewing machine I hope this helps
RBerry9511
02-07-2020 04:31 PM
Jklnhyd
03-14-2014 10:27 PM
nickh
01-24-2007 08:53 AM
