How many miles does your bronco have?
#62
Originally Posted by mds01
Well I average 1000 miles per year so Ill talk to you again in 2032, keep up the good work.
In my case, having a girlfriend 300 miles away is one reason for lots of miles.
BTW, in my case everything happened after 135k -- fuel pump, water pump, rear end, and alternator. None of these were preventable -- they just reached their end of life. The previous owner (WA state government) may have known that the rear axle had problems because they did attempt to take it apart, but broke the pinion shaft bolt instead.
#66
#67
82' over 500,000 km's, have swapped out engine(351), tranny rebuilt, Diffs swapped out for D60's soon to have 5:13's runnin on 39.5 swawmpers with bead locks. Still runs like the day it rolled of the show room floor which was purchased by my Dad in 82 and i bought it in 90' and still goin.
#68
My 79 has 67,000 HARD miles on it. It started life as a ranch rig running up and down crummy roads and hauling hay bales, tack, etc. When I picked it up it had bent pushrods in the 351M engine, so I replaced cam, lifters, pushrods, valve springs, etc. Everything else is pretty much OEM. Every thing I have replaced on it so far has had a Ford Oval stamped on it, lol.
#71
Originally Posted by aurgathor
Wait 'til 150k and see if you can repeat the above...
Yes, mine *was* fine at that point, too.
The motor runs like brand new. No stumbles, no noises, no smoke, dry spark plugs, and it idles so smooth that you can hardly tell that it is running (5.8). I am hoping that my E4OD makes it to 200K. It works fine now.
Keep knocking on wood...
#72
#73
1979, 177k...motor rebuilt at 140k only due to many leaking oil seals, internals were all good, general maintenance and replace 9in w/5 lug d60 when 9in blew up many years ago...daily driven 200 miles a week...allows my 00 f150 to sit around and wait for me to go out of town or tow the jeep to the trails...
mac 'can't beat the old iron' gyvr
#74
I bought my 95 in September of 1998 and it had over 80,000 at that time. I have increased that to over 260,000 since then which makes approx. 30,000 per year. I've had some front end work, a couple of serpantine belts, heater core, heater hoses, 2 water pumps, 3 complete brake jobs and a vibration damper replaced. So far, she's still running with no MAJOR problems.
